car is over heating
Car started overheating. Reservoir filling up with antifreeze and bubbling. Did a block leak test which showed no combustion gases. Changed radiator cap. Did pressure test on radiator and found water pump was leaking. Replaced water pump. Bled air yesterday and drove car for about 30 minutes.A/c and heat worked well. Later yesterday I drove car about 5 miles, and it was doing fine. On way home I stopped at store. When I tried to crank car to come home car wouldn't start. Checked battery cables and made sure they were tight. Tried cranking again, this time giving it gas and was able to drive car home, about 1/4 mile. This morning tried starting car and it started right up. Turned heat on, and no heat. Decided to try bleeding air again. Reservoir filled up with coolant and was bubbling again. Please help. Need car and running out of ideas. Someone point me in the right direction. Thanks
この質問は役に立ちましたか?
