メインコンテンツにスキップ
ヒューレットパッカード(HP)は1993年よりパーソナルラップトップコンピューターの製造を開始しました。
1891の回答 すべてを表示
Laptop get wet and won't turn on
My laptop get wet 1 years ago.I took it into repair centre .he looked and said it could be possible if water dries itself .Now its 8-9 month nothing happen it won't turn on neither it charge. Any possible solution
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
It is likely that the water has caused the components on the motherboard and other PCBs to be damaged, stopping it from working. If it is financially viable, you could try replacing the motherboard/damaged PCBs. Since it does not charge, it is likely that the motherboard is damaged.
この回答は役に立ちましたか?
スコア 0
コメント:
It might also be better to just get a new laptop
by
@Cameron Like I said, "if" it is financially viable. If the laptop is quiet old then it is definitely better to get a new one.
by
コメントを追加
最も参考になった回答
Hi @kcshyam ,
What is the make and model number of the laptop?
For starters, after 9 months not being used (or charged) the battery is most probably beyond recovery and will have to be replaced. Especially if it also got wet and was left inserted in the laptop
With HP laptops it is usually possible to get hold of a service manual which will help you to disassemble the laptop so that you can view the extent of the damage.
Once it has been assessed then decisions can be made as to what can be done, if anything, to try and resurrect the laptop to a working condition.
この回答は役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Shyam さん、ありがとうございました!
統計データを表示:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 61
今までの合計 2,330
