How do I remove the drain plugs on the floor pan of a 2002 Volvo S40
My Volvo S40 has been in a flood and I need to drain the water out through the floor plugs. How do I remove them?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
denfun09, If you have access to a shop vac, say your buddy or family member has one would also remove the water for you. The floor plugs normally pried out with slotted screw driver/wedged under lip and pry up. If they have some sealant on them may have to heat up a bit with heat gun/hair drier to ease removal. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 661
