メインコンテンツにスキップ
Appleの iPhone 5sは2013年9月10日に発表されました。このデバイスの修理は全モデルの修理と類似しています。そしてスクリュードライバー、こじ開けツールが必要です。GSM か CDMA、16か32、64GBがあり、色はシルバー、ゴールド、スプレーグレイが選べます。
3954の回答 すべてを表示
Top speaker problem in my phone
When i receive call i can't listen them properly. I have just replace screen 4 month ago and when i tried for video call and set up loud speaker another person in call isn't able to listen my voice but they can listen to me when i use headphone
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Look at the hole in your screen, where there is a small piece of black mesh.
Behind that mesh there are the ear-speaker from which you listen when phone is near to your ear AND the mic from which you talk when in loudspeaker mode.
If this issue happened some time after your replaced the screen, and the sound became lower and lower with time, there is probably some dirt on the mesh. Brush it clean with a toothbrush dipped in iso propyl alcohol (90%+) or even scrap with a needle and then punch 3-4 tiny holes.
If this happened immediately after you replaced the screen and you can't hear any sound at all, then that cable is damaged; or you did not click it in place properly; or there is a small piece of film covering the hole that you failed to remove before transferring the cable.
この回答は役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Shyam さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 24
