メインコンテンツにスキップ
GMCが製造した車、トラック、SUVの修理ガイドとサポート。
290回答 すべてを表示
Why my doors and window not working
I was working on my gmc envoy xl climate control when i put it back on for some reason my doors and windows do not work but with my fob im able to lock the back doors and liftgate but not the front can anyone help me?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
There are really 2 things to check. One is the fuses. Remove and inspect every fuse for is they are blown. If they arent, remove the climate control and check to see if you have any pinched or damaged wires. If you do, you probably need to resolder them, but if its not bad, you might get away with some electrical tape. If you find a blown fuse, replace it and it blows instantly, then you know there is a short, probably near the climate control as thats where you were messing around.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Cant find no wires there are so many of them and hard to get too there is power from the main terminal thats go into the master switch but nothing works i change it with a used one but still does the same thing
さんによる
I checked the fuse they are not blown and the circuit breaker are working replaced it with a new one
さんによる
コメントを追加
回答を追加する
Baudilio Roman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 51
