メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
Wifi Board Controller connectivity issues
My console had this issue where my remove would lose connectivity with the console. It wouldn't power down or turn off just disconnect and reconnect. Which is quite awful. As per many write ups and lots of research, I replaced my wifi board which a unit from iFixit! After reassembling the console, I was able to play for a solid 2 hours and everything was awesome. The second time I tried to play anything I having the same connectivity issues and now get randomly booted off XBL when the controller disconnects. Is it possible the second wifi board is dead or do I have a bigger issue? Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
9 件のコメント:
Is ur wifi good? I have this same problem. It depends on what game u r playing, how much activity there is, and how many people there r when it disconnects.
さんによる
Wifi is perfect, no other devices connected other than my xbox and i still have the same issues :(
さんによる
Oh. U mean remote instead of remove. Duh. Did u try a different controller?
さんによる
Multiple controllers, no other electronics on wifi... Im at a lose
さんによる
I am not to sure, but I think the remotes connect with bluetooth. Is the wifi and bluetooth integrated on the same board? I will ask this question on ifixit and see what I can get. It might be a bit so hang in there. I will try to get this fixed.
さんによる
4件以上のコメントを表示
コメントを追加
3件の回答
Is your Xbox up to date? Out of date; controller software or the software on the xbox itself might be an issue. uplug the xbox whille its of wait 30 s and repluc and turn on, this will load the screen, and perhaps some updates you mights have missed they have been 2 lateley.
このアンサーは役に立ちましたか?
スコア 0
10 件のコメント:
No matter what, xbox always auto updates. And if you try playing with a controller that is not up-to-date, then it will auto update so that you can play. He was also able to play for a short period of time. Didn't you have that with your xbox?
さんによる
No, I always had to do the unplug situation; if its not software, must be the controller possible some interior physical damage. Dropped the controller recently or ..... thrown it?
さんによる
Yes but he said he used multiple controllers. It could still be a possibility though but more slim with two or more controllers.
さんによる
We could also entertain the idea; that the console may be the issue as well. Its like, when you have wifi issues if all things are connect with no issue and one device isnt its the device, if its all then you reset the modem. You should try connecting the controller to a friends XBOX as a test. If it connects then ist the console
さんによる
Yes, binary exclusion. But what if u are like me and you don't have friends?
さんによる
5件以上のコメントを表示
コメントを追加
Just replied wifi board with "new" one from iFixit
And the disconnect issue still persists
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Games like Fortnite and Cod Bo3 are the games I’m having trouble with. My controller will disconnect and I know from there that either the game will crash in a few seconds or it will put me at the home screen if the game. It tells me that my WiFi connection doesn’t exist but clearly my wifi is fine. It will then proceed to reconnect 5 seconds later. I find it annoying because it is becoming more predominant.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That is my same problem. Have you found a way to fix it?
さんによる
コメントを追加
回答を追加する
Albert Hutchinson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 10
今までの合計 3,332
