メインコンテンツにスキップ
Need Adaptor and Power Cord for CyberHome CH-LDV 712 DVD Player
Hello. Does anyone know where I can purchase a replacement adaptor and power cord for the CyberHome CH-LDV 712 DVD Player (almost new, purchased around 2006, but hardly used than one time)? I have misplaced the adaptor and power cord. Thanks, in advance, for any help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Camille Nixon, I believe the link below may work for your CyberHome CH-LDV 712 DVD Player. You can also do a search for better pricing perhaps. You could probably take the player to an small electronics shop(Radio Shack/ the Source) or for that matter big box stores also sell multi plug adapter that can be matched up to your DVD. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.ebay.com/itm/CyberHome-CH-LDV...
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Camille nixon those AC power adapter are widely available at places like this and many more. You can always go to places like Walmart and purchase a universal adapter with variable outputs. Those will have interchangeable power connectors. Your player requires a 10VDC 2A AC power supply with the center (tip) being positive and the outside barrel (ring) negative.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I found that I need two parts for the CyberHome CH-LDV 712: the "brick", power cord and adapter. I saw the power plug advertised, from your excellent replies, and will order it, but does anyone know where I can purchase the part known as the "brick"? I need both parts to get the DVD player working. Also, is it possible to find another battery, just in case I need to replace the one I have?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Camille Nixon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 93
