メインコンテンツにスキップ
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
426回答 すべてを表示
battery drains when its at 100%
Well the viking pro lolipop is the best tablet in the usa but if you anywere play on it every 24 hours the when you plug in overnight and when it gets to 100% i unplug it
and it starts draining how do i fix it???
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I too have an Android Viking pro 10 not more than a 8 months old and the battery will not hold a charge longer than 15 minutes. I have tried turn resetting the tablet back to factory, and turning everything off. But it still will not hold a charge longer than 15 minutes. I do not have the receipt anymore due to the Fire storm we had here last October in Santa Rosa ca. I have even asked for information as to were I can buy a battery if it is possible to replace but RCA or anyone will not give me that information. I have asked what the cost will be before shipping it back to RCA, but they will not even give me an estimate. It may be cheaper to purchase a new, but different brand of Tablet.
So does anyone have a clue as to were to buy a battery and or if it is even possible to replace them, or is this just a throwaway piece of technology? Thank you, to it may concern.
さんによる
コメントを追加
3件の回答
ベストアンサー
Android tablets don't actually turn off when you close them.
When your battery is fully charged try turning it off by holding the power button for a few seconds.
You could also try being proactive managing your power usage, turn off bluetooth, wifi and any background apps that you may have running.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
That does not make sense as it requires my wifi to be on to play my games!
さんによる
I have similar issues. Had my viking 10 pro for about 8 months now and it works fine but, lately will not keep a charge for long. Even when plugged in the plug gets quite hot over taxing it no doubt. When the unit is completely off and charging it will charge normally. Shutting down apps while in use is kind of counter productive just save a bit of power. Deciding which app is using more power in the background to be shut off or deleted is likewise counter productive. If these tablet models are so great why do they have a cheesy battery ? Plus most computer repair shops figure at the cost of changing the battery for a new one you can buy a new tablet.
Could it be possible if one gets malware that the malware is taxing the battery. There are so many anti malware apps that claim they can detect and clean out. Yet, how does one know the very app to be used to clean malware is malware?
さんによる
Hi @ C N
The malware could be going online in the background without your knowledge.
You have to go on trust with most things.
Select an anti-malware app that has a good reputation, install it run the app and then when it is finished delete it.
Unless you have an AV system installed that you trust that is constantly monitoring for malware and viruses in your system (which in itself utilizes resources) you have to use something occasionally otherwise you're leaving yourself totally exposed when you go online.
This app has been around for a long time with not too many adverse reviews over the years
There are others.
Do some research and then at least try one, uninstall it after it has cleaned any malware/viruses from the system (if any) and check the performance of your tablet to see if there is any improvement or not
さんによる
コメントを追加
I have the RCA RCT6203W46 10" Tablet 16gb With Keyboard and with a full charge, I get right at 1 1/2 hrs before it shuts off. i don’t have anything running except Wi-Fi, a youtube video running and a Chrome gmail window up that’s not doing anything unless i tell it to. This seems really inadequate to me, these batteries should last longer. and btw, this has been the same since i bot it new fm Wmt. Anybody else have this same thing and short of replacing battery or killing all the apps, any ideas?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The battery is low quality and will run down even if it’s kept plugged into, charging. It’s rated at 4000 MaH 5v 10w 2A for charging and power. I wish they made a higher capacity battery for this model. The battery can be replaced there’s many videos that show how to open it up and replace parts. I replaced the screen I broke by following these instructional vids on YT, just search there. Maybe a new replacement would help, it’s not hard to find them.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
coffeecreameranimations04 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 5,021
