メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
このインスタントカメラは富士フイルム製で、前モデルと比べるとよりスリムに、より軽量なデザインです。Mini 8はフォトグラファーに適切な明るさの設定を自動で点灯して教えてくれます。またフラッシュ機能をハイキーモードに設定すればアーティスティックな美しいポートレート写真を撮影することができます。
Everything works but the films r not coming out
The flash works, the lights on the camera works, even after I take a picture the sound of the film coming out is there but the film just won't come out . I changed new pack of film and still the same thing. I thought might be that pack so i changed another pack of new film. Still there the flash, then the sound but the film is Stuck and won't come out. Please help!
I never dropped it before, it was always well taken care of.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
6 件のコメント
How do I eject the film? The film is not coming out. I have a Fujifilm Instax Mini
さんによる
Someone, PLEASE HELP ME WITH THIS PROBLEM!!
さんによる
I have a similar problem! Except I initially put the film in backwards. Now it sounds like it wants to eject but nothing comes out
さんによる
I have this problem but I accidentally Put it in back words
さんによる
same , i was taking a photo for my brother and i accidentally put it in back wards and now when i do it the film makes the noise but doesn't come out
さんによる
1以上のコメントを表示
コメントを追加
12件の回答
ベストアンサー
@bbluu0310 ,Baybie Luu , Found this info. at the ifixit trouble shooting link below.
If the film does not come out of the camera, check the back cover and film ejection slot and check if there is anything blocking the photo ejection slot. There is also a mechanical roller in the camera which is used to eject the film from the camera. Once the film is removed, release the shutter to determine if the roller is functioning properly.If camera still under warranty return for repair/replacement/refund. I will also post a link to show how to disassemble the camera to check for poor wire connections,dust,debri,etc. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Fujifilm Instax Mini 8 Troubleshooting
Fujifilm Instax Mini Eight カメラシェル(筐体)の交換
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
I had the same issue, and I had to peel the little sticker off of the top so the film could make its way out.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
I just peeled off the sticker and it still wouldn't come out
さんによる
Thank you !!!! This was my problem too ....my 16 yr old loaded it and if I wouldn't have read these posts .. prob would've thrown the camera against the wall ?
さんによる
Also put new batteries in ... Just in case
さんによる
コメントを追加
Also make sure you press the shutter before winding the “practice film” (aka the plain black film that’s not actually a picture) out.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Do you need the black film every time
さんによる
コメントを追加
My films were working just fine until now what do I do?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
SAME HERE! What do we do??
さんによる
I took the plastic shell off of mine and found that a screw had fallen out and gotten jammed under the lever that pushes the pictures out.
さんによる
@mendegrace14 How were you able to fix it?
さんによる
コメントを追加
Check if there’s film in there, the same happened to me and I checked the film box thing and it wasn’t in there.once I put it in it worked again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi…my instax square sq 6…are not opening…what would i do? Do i have to change the batteries?i just used it only once
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi , my instax mini 9 just went off as soon as I changed the film, it’s not coming out and the black film isn’t coming out plus the film is stuck , please what do I do
さんによる
コメントを追加
My Polaroid keeps flashing. I put in a new roll and batteries but when I go to take a picture it starts flashing
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My camera won’t let me take pics flash doesn’t come on, it won’t eject pics, and is stuck on s, my brother put the film in backwards and now jus won’t work at all. I changed batteries and still not working
さんによる
コメントを追加
my lomo instant camera is brand new and it makes a clicking noise whenever i try to take a picture. it’s brand new film and it won’t print anything out
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Peel off the little black plastic sticker on top ...so film can come out
さんによる
I tried that an it didn't work. Just make a clicking noise
さんによる
コメントを追加
Hello, my instax mini 70 cannot read/recognise the film. I put a new film but it shows that zero photos left to shoot just like it was empty. What can I do?? Please help I ‘m leaving on holidays in a few days and I need it!!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have the same problem did u find out why?
さんによる
コメントを追加
I have an instax mini 8 and when I inserted the new set of film and taken a shot to remove the plain black, it takes a flash but the plain black did not come out. After that, the camera lights turned to red and all of the lights were blinking. I have tried to remove the film out of the camera but it can’t be removed, it seems like it is stuck. The upper part is stuck but the lower part of the cartridge already came out. What should I do? Can someone please help me?
Can the film cartridge be removed out of the instax camera even if it is not used?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi! I’m not sure how to add a picture but I just had the same problem and here’s how I fixed it. If you take ur film out at the bottom right on the inside of it there is this silver metal hook type of thing and for me there was a clear piece of plastic stuck to it blocking it from moving so I just removed it and now mine works just fine!
さんによる
コメントを追加
I had a very similar problem, so I took the film out and studied it to realise it was slightly bent in the area which the photo comes out from (I will attach photos) and so I tried the 2nd film and and was absolutely fine!
画像
画像
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Had the same problem where everythingseemed right but the film wasnt rolling out. Doh! My film was upside down! I unscrewed the whole thing and all.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bebe さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 84
過去 30 日: 371
今までの合計 172,960
