メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
Why won't my computer charge from any charger?
My MacBook Pro (OptiBay'd but besides that mint condition) has periods where it will not charge. I have tried using other chargers and other outlets and it just does not charge at all. The MagSafe adapter light stays off too, and jiggling the cable around does not help. Then, eventually after seconds or many hours, it works again. This started off only happening occasionally but now has been happening for ~8 hour periods with only a few minutes break.
Other symptom is that I keep having random shutdowns where when my computer boots up again, my clock is reset back to 2000 and my Airport needs a password again. I have tried resetting the SMC/PRAM (dunno if that worked though).
Please help! What do I replace or do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Was it dropped? Water damaged? If no, and you are able to put it in factory defAults, just take it to apple store. They should deal with it...
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
+ agreed - take it in and have the warranty work done. Sounds like the magsafe port has gone bad. You probably reset the clock when you zapped the PRAM and have not signed on to the internet.
さんによる
コメントを追加
回答を追加する
CStigler さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 1,407
