メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone 5s water damage, gets warm but won't turn on
so i have 2 water damaged iphones 5s that won't turn on and seen by itunes. already cleaned with alchol, changed battery but no result. quess there are parts shortened. but i don't know where to look. will be grateful for help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Sounds like they are done. Probably no fixing these, sorry
さんによる
They will be if nobody says me components to check)
さんによる
コメントを追加
1 件の回答
ベストアンサー
Well, first let's stop putting electricity into these devices. Second let's find a good repair shop in your area that has an ultrasonic bath and does board level repair work. Or if you don't/can't find one in your area, iPad Rehab does the best work in the country and has an amazing mail in service. I do appreciate that you tried cleaning it with IP yourself first. But sounds like a tooth brush isn't gonna take this time
EDIT: Again the ultrasonic bath with bransonic, or an equal quality electronics cleaner with distilled water is the best solution. Before going microsoldering. Test a known good battery, lightning dock, and display. Yes, read what you wrote, you charged a battery
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I am the service and I am from Italy. Cleaning does not help as I've said before, need some more concrete answers about components on motherboard to check
さんによる
Ok. Cleaning with alcohol is not the same as cleaning with an ultrasonic bath. If you are a board level repair shop you'll want to use your multimeter to test continuity on the u2ic and maybe the pmic
さんによる
Thanks! u2 is ok, will look pmic
さんによる
コメントを追加
回答を追加する
iloveclipse さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 300
