will not turn over, got lights radio,etc
1992 gmc serria pickup turn key on got lights, etc. will not turn over
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@jj253 , Ernestine, Even though the lights do come on, the battery could be low or bad connections, check for 12.2v+ at the battery,check connections on battery and follow them to their other end to ensure not corroded or loose. If need be try boosting. If truck starts, problem will be weak battery or bad connections.
When running if the battery is not showing 13.8+v, the alternator may be weak also.
If battery, connections, fuses/relays all look good, with foot on the brake, if automatic, shift out of park and try starting truck in neutral and other gears, this will maybe tell us if the safety neutral switch is out of adjustment, but could still be faulty, just as on a standard tranny the out of adj. or faulty clutch switch can cause this issue.
Now if able to access the starter give it a couple raps with a heavy object(hammer/metal bar) careful not to hit solenoid. After giving starter a couple good raps, try starting if it starts, the starter is sticking and faulty.
Now if the above had no effect and you can access the 2 large solenoid terminals and safely cross them out with a screw driver and truck still will not crank then the solenoid/starter are faulty.
Some of the auto parts suppliers offer free battery/starter/alternator testing, like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
https://www.youtube.com/watch?v=mDIlwbx0... That might be the issue. If it isnt please give more details.
このアンサーは役に立ちましたか?
@jj253 "will not turn over" should prompt you to check the starter first. Start with this trouble shooting and let us know what you find.
@jj253 if you are more of a reader, here is the part that deals with the starter GM Starter. It will explain the trouble shooting as well as the repair.
このアンサーは役に立ちましたか?
@oldturkey03 I think the problem he is facing is that it cranks, but will not turn over. If its not cranking at all, its the started but if it cranks but don't start its probably the fuel pump.
Even if you can hear the fuel pump engage? I replaced my distributor cap, module, and the distributor point cap..cranks but will still not turn over.....help!!!
@messyjesi well, you need three things. Air, Fuel, and spark. Do you have spark and do you have fuel coming to the engine? Make and model of whatever you are working on might be helpful.
過去 24時間: 2
過去 7 日: 56
過去 30 日: 185
今までの合計 8,304
2 件のコメント
Do you get a clicking from the solenoid?
mayer さんによる
So I got a new starter and battery and my truck won’t start, so I tried the next morning and it’ll start but turn straight off right after so I’m not sure but I wanna guess the icm?.
FaZe Clout3 さんによる
