losing water out of back engine
losing out of back engine
この質問は役に立ちましたか?
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
評価: 1
I was a Chevy tech for 20 yrs...couple of areas to look.
There could be a connector at the rear of the intake manifold that connects a metal pipe from the manifold to the heater core. Those get corroded over time and can leak.
Also the intake manifold gaskets themselves can leak in that area too.
You can rent a coolant pressure tester from the parts store and pressurize the system to locate the leak.
Hope this helps
評価: 1
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 925
where in the back is it leaking? Within the bellhousing, above it or the sides of the engine toward the back? How much water is leaking out, how often do you have to replace the fluid? Need a little bit more info to give you a better answer since there are plenty of opportunities for leakage. Thanks
oldturkey03 さんによる
