power button does not do anything
dead...how do i fix it ?
Does it make a difference if the power cord is attached or not?
You could try resetting the SMC: with MBP plugged in, press and hold CMD-OPT-SHIFT and then the power button ( I generally hold them for a ten count). You should see the charge light on the pwr adapter flip color (from amber to green or vice versa) after you release all. Then try powering on.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 21
