@ow0 , ow0, Maybe try straightening pins carefully with a toothpick, if no success then consider the changing of port. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the calculator to check the charge port and will also post a link(not your device/same repair) showing what is involved in repairing a mini USB attached to the board in case you would like to give it a whirl. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. You may have to find/match visually replacement port, when doing a search. Good luck.
https://www.youtube.com/watch?v=Fdt1zGb0...
https://www.youtube.com/watch?v=rTim6FIJ...
