All my apps on my phone are in black and white
My apps on my home screen and on my app display
Check you have an app called colour catcher, tis solved my son's problem
このアンサーは役に立ちましたか?
yes! i tried resetting the phone, I tried the settings, i tried online setting everything! then this and it worked thanks!
Ok what was the apps name specifically,
Turn off bedtime mode
4 steps- Setting..Accessibility mode..Vision.. Then Color Inversion...
このアンサーは役に立ちましたか?
Works... Thanks
You might have some kind of accessibility mode on. If you go into settings and look for an accessibility menu, then look around for a black and white mode.
このアンサーは役に立ちましたか?
I tried that and my phone don't have a black and white feature
try Setting..Accessibility mode..Vision.. Then Color Inversion..
under accessibility, select vision and make sure greyscale is turned off. not sure how that happens, but I have had a customer in the same situation where he didn't know how it got turned on.
このアンサーは役に立ちましたか?
Ok I know I did something but not what I did. My TMobile revvl4 is showing some things in color but not all. Like the chrome icon shows color but the app is black and white my game icons are color but the games are not
I have tried the steps listed in the how to fix it but none of them have worked.
PLEASE HELP ME OUT!
ITS DRIVING ME CRAZY!!
このアンサーは役に立ちましたか?
I had the same problem. You need to find the reading mode for your phone, and go into the options for it. There should be a section for individual apps, you need to manage which ones are in reading mode, hope this helps you
過去 24時間: 0
過去 7 日: 3
過去 30 日: 42
今までの合計 16,782
10 件のコメント
Is this an Android?
Nikola Wozniak さんによる
Yes my phone is an Android
Alton Wilkes さんによる
Please - put this phone back to a normal reading.
cheneys33 さんによる
Everything in my phone is black and white how do I get my color back
darou87 さんによる
darou87 さんによる
5件以上のコメントを表示
