メインコンテンツにスキップ
An all-in-one inkjet printer, scanner, copier series by HP. Model number CX042A.
27の回答 すべてを表示
Missing parts of document - tops of words and complete lines
My printer is missing the top parts of words, and also complete lines of text. I've tried renewing cartridges - even though the black one showed nearly a full cartridge., but the problem still persists. Any help would be appreciated.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Thanks for your help. I had to carry out the procedure 3 times, but in the end I had a perfect result. Many thanks.
by
Your welcome! I'm glad I could be of assistance to you.
by
コメントを追加
1 件の回答
選択されたソリューション
Sounds like you need to clean the print heads. You can do this within the menu or, if you have the application do it from your PC. Also try aligning the printer.
この回答は役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Marjorie King さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 17
今までの合計 624
