Optical Bay for SATA HD
Hello.
I bought a SSD for my macbook pro 15 "2.33 Ghz.
But now I would like to replace my superdrive with a optical bay, but I do not know if
must be SATA or ATA.
Can you help?
Thanks Vincenzo
この質問は役に立ちましたか?
Hello.
Can you help?
Thanks Vincenzo
この質問は役に立ちましたか?
UJ-857 Specifications
Interface IDE/ATAPI
Buffer Memory 2 MB
Power Requirements DC +5V, 2.0A
Operating Temperature 5~60 °C
Operating Humidity 5~90 %RH (Max. wet bulb temp. is 29°C, Non-condensation)
Loading Method Slot loading
Dimensions 5.07” x 5.03” x 0.5”
Read Speeds DVD-ROM 8X, CD-ROM 24X
Write Speeds DVD-RAM 5x, DVD±R 8X (SL) 4X (DL), DVD-RW 6X, DVD+RW 8X, CD-R 24X, CD-RW 16X
このアンサーは役に立ちましたか?
Sorry if my answer wasn't clear. Here's what you need: [リンクされた製品が存在しない、もしくは無効: IF107-078]
You need a PATA to SATA optibay. I put one in my computer and it caused me to freeze once a day. I tried one more to see if it was bad and the same thing happened. Not sure but it was unstable.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,616
