メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
2014年9月19日に発売されたこのiPhoneは4.7インチのスクリーンサイズでiPhone 6 Plusの縮小版です。
5168の回答 すべてを表示
Why wont my phone turn on?
My I phone 6 has been putt away since i brought a 7 and i want to get it back out,
i have tried charging it for ridiculous hours and plugging it into my computer but i still cant get it to turn on.
When i plug it in the screen brings up the low battery logo, it then brings up the apple logo and turns off again.
If you have the lights off you can see the phone tries to turn on a glows a navy type colour.
I took it to the phone repair man to see if it was the battery and it did the same thing with a new battery in it.
please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
I'm sure the repair man had the knowledge but just a thought, was the new battery that you tried a brand new out of the box battery or one that he knew was good? A new out of box should be charged before it gets used or it may not be charged in itself because I'm sure most batteries recommend to charge before the first use.
さんによる
Did this iPhone have any damage before you put it away ?
さんによる
コメントを追加
1 件の回答
I would suggest trying to unplug the power button flex from the circuit board and plugging in the charger and see if it will come on then, if that doesn't work try a new battery, charging port, screen and if all else fails plug it into iTunes and put it in DFU mode and do a restore. you will lose all info.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
emmafinemore さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 130
