メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3531回答 すべてを表示
Drop on back bootloop, repair shop fail
I'm currently travelling, and whilst in Cuba I proceed to drop my phone flat on its back which causes it to bootloop. This happened to me in Canada as well, where I opened it up reseated the display cables and was good to go, when I tried this in Cuba, it did not solve the problem. It was and is still in a bootloop on the apple logo and then black.
From research on this site I assumed it was an issue with the battery, so I have taken it to a repair shop where they reseated it and tried a new one, but it failed to fix the issue. It is still in a bootloop.
They gave a load of excuses and no real reason to why it is broken other than my jailbreak my have been the cause, which I find very hard to believe. They then suggest that I try a restore, which I have just attempted to which I get error (9). Which I think means a hardware issue.
If the battery is not the issue, the only hardware problem I can think of is from screwing the wrong screws on the guard of the display cables, would this be the cause? How do I go about checking this and fixing it?
iPhone 5s 10.2
Jailbroken Yalu b7
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Did you try a DFU mode restore?
さんによる
I haven't, sadly my laptop has died so cannot restore at this point, I will give this a go once i get my laptop repaired
さんによる
Finally have my laptop up and running and sadly this does not work, DFU restore simply returns the same error 9
さんによる
コメントを追加
2件の回答
最も参考になった回答
on my quick 2 minute research it seems error 9 is an error in updating i have found this link though witch could help a lot.
How to fix iTunes error 9
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
For me it sounds like a corrupted NAND
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
what does that entail? sorry no phone and now no laptop, whilst half way across the world, so can't effectively google
さんによる
This is the device's memory chip.
さんによる
Sweet, apologies for my ignorance, I'll email some repair shops see if they can fix this issue
さんによる
コメントを追加
回答を追加する
charlie.smith142 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 72
