メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2688回答 すべてを表示
Display spoil after refurbish lcd.
Hello, recently when I'm doing refurbish 6s/6s Plus LCD I found out that everytime I done cleaning the oca on the LCD after removed the polarizer then the ribbon spoil. I found it when I'm doing the last check before put into the machine. The problem is when I touch the LCD ribbon or trying to flip gently the display gone strange. I was wondering is it the oca remover caused it or the static. Please help!
Update (03/27/2017)
This is the problem when you touch the flex or flip it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
If the problem not serious the LCD still usable.
さんによる
What does the LCD look like exactly? Can you post a photo? When you remove the polarizer the static line at the top is usually also removed. Which causes a ghosting effect until it is re-applied later in the refurb process
さんによる
Question updated. Is this what you called it ghosting effect?
さんによる
I used 8333 and zippo to clean the oca glue after removed the polarizer.
さんによる
コメントを追加
1 件の回答
ベストアンサー
You are better off posting this in the iFixit Pro Talk forum where pretty much business owners and etc talk to each other. There are many good LCD refurbishers on that forum that go in depth about these issues and the solutions to them.
https://talk.ifixit.com/
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Ong Kim Sheng さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 147
