メインコンテンツにスキップ
The Samsung L100 was a Digital Camera that was released in February 2008.
10回答 すべてを表示
Why wont my camera charge or turn on
the lens is still sticking out.It will not charge.And it will not turn on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
How is your battery charge? Did anything happen to the camera i.e.getting dropped, water exposure etc? could be that you need a new battery. Is it charging in a external charger and does the charger work. You might want to check that with a multimeter to eliminate the battery as a culprit.From what I found out there may also be an issue with the lens motion strip and that could cause your cam to act up. Do you have any error code beeping from your cam?
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
My camera has been dropped but it was working after that.When i charge it, it has a red light that says on for a few seconds which means its charging but then it starts flashing which means its not charging do u know whats wrong?
さんによる
Heba, you are charging on en external charger I suppose? I would definitely start with a new battery.
さんによる
Camera has a new battery fully charged but will not turn on. nothing happens
さんによる
@keithgill same camera? Besides a new battery, what have you tried?
さんによる
コメントを追加
回答を追加する
Heba さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 3,972
