メインコンテンツにスキップ
Repair guides and support for the first generation of Sony's RX100 high-end compact camera. 20.2 MP sensor / June 2012
17の回答 すべて表示
The EVF does not release when lever is pulled down
The pop up view finder seems to be stuck on my new DSC RX 100 V. How can I release it?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
@mayer or @oldturkey03,
My answer to this was deleted because I mentioned the Sony support number. It gave 402: deleted due to spam.
BTW, if you feel at all anoyed by my calling you when something like this happens, please say so.
による
@pccheese George, not at all. Try giving the answer. Then leave the number as a comment and let's see if that works.
による
@pccheese I was able to delete the previous answers properly so you did not get -100 points for spamming ;-) Got to watch iRobot when it comes to support phone numbers etc. iRobot recognizes those as spam probably due to the influx of fake support numbers over the last couple of months.
による
@oldturkey03, I think something is wrong because it didn't discount my rep before, but now it's over 100 rep less than after I posted my answer! I don't understand.
による
@oldturkey something is going really whacky! My last comment was deleted and now my rep has dropped -300 in the last twenty minutes!!!!! Please help!
による
表示する 1 他のコメントを
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
1回答
選択されたソリューション
Seeing how the camera was released so recently, you are probably still under warranty. You need to contact Sony esupport using the info in the comments below. Before you send it off though, push down and try wiggling the veiwfinder a little incase its just sticky. Hope this helps!
この回答は役に立ちましたか?
スコア 4
コメント:
Contact Sony esupport phone here: 1 dash 888 dash 476 dash 6972.
による
sony.esupport.com
による
コメントを追加
回答を追加する
sdyer さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 218
