No Sound from any input source!
Hello, I have a Vizio XVT323SV, 32 inch. Out of no where one day, the sound stopped working. Everything else works just fine and the picture is perfect. All the built-in tv apps also work fine. There is just no sound. There is no sound when headphones are plugged in either, no matter the video source or built-in app playing. I would rather not replace the entire tv if I can replace a specific part myself. What do you suggest the cheapest way to fix this is? And if a part does need replacing, what part would that be?
Thanks!
この質問は役に立ちましたか?
1件のコメント
Have you verified that the tv speakers are "ON" in the audio menu? Also does the volume level bar display when you use volume up or down?
Lewy さんによる
