My speedometer stopped working after the radio was stollen
how to fix speedometer after stereo was stollen
Matthew Budau , Check all your fuses if all test good, you will have to look under dash and examine all the wires/plugs to see what all got cut, loosened or damaged and make necessary repairs. I hope the links below may also help, wire color codes and schematics. It could also be a problem with stepper motor behind the cluster which may have failed, last link below. Good luck.
http://www.jalopyjournal.com/forum/threa...
http://www.autozone.com/repairguides/Ava...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 148
