メインコンテンツにスキップ
The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
19回答 すべてを表示
Why is it not blowing cold air
My fan works but doesn't seem to be blowing out much cold air anymore
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
6 件のコメント
I have the same problem. Paid £320 for the fan and it’s useless
さんによる
Keep it clean and should be fine, they do require some maintenance if it is in a dusty and fluff environment, get a vacuum cleaner and suck all the dust of the air intake and motor and amp as much as possible or it's that bad use a compressor as suggested before
さんによる
If these are used for heating and cooling, they get moist and the dust collected becomes wet and mud like and glues to the body closing all the vent holes. These can't be cleaned by a vacuum cleaner. It requires disassembling/opening the body of the air multiplier and if possible wash clean the intake holes.
さんによる
Opening the body is not simple, several step needed and some technical know-how.
さんによる
I just recently bought a Dyson cool fan but it’s not giving me cool air and there’s a smell when I turn it on
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
loopyshaz222 , Try and disassemble the fan as much as you can and use vacuum/compressed air to blow out all the dust/lint/etc. that may have accumulated from base vents/motor and the loop to help bring back it's efficiency. Links below may help. Good luck.
https://www.manualslib.com/manual/888752...
https://www.youtube.com/watch?v=Y7Z-Zn0r...
https://www.youtube.com/watch?v=5NAQv6RX...
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
All this I have done.
I vacuum every other day.
Fine dust has clung to the inside fan. Thus impeding air flow.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
loopyshaz222 さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 33
過去 30 日: 144
今までの合計 63,181
