メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Bottom half of screen doesn't respond correctly
I have an iPhone 5s that doesn't respond correctly on the bottom half of the screen. It works but when using the keyboard the input is wrong, for instance if I touch F, I might get G or G and F. It is not the digitiser, the screen has been replaced with one that was working perfectly on another 5s so it is something within the phone itself, any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
A few things to consider here:
  • The logical thing to suspect is the screen. If you are confident it is good (can you put it back on the original device it came from to confirm?), then move on to the next item
  • There may be a partial connection only so check the digitizer connector. Also, it should have a little black foam on top of the metal plate on the flex (look at this picture). That allows it to stay firmly connected under the bracket. Don't underestimate the importance of this.
  • You could have a problem on the logic board with the Touch IC. If the phone was bent in the past or dropped often over it's lifetime, this is a possibility. This would require a micro-soldering repair.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I definitely sure it's not the screen. The screen that came with it was the exact same way. So it's going to be one of the other 2. I'll open it up tomorrow and see if I can see what the problem is. Thanks.
さんによる
コメントを追加
回答を追加する
Mary Ellen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 73
