メインコンテンツにスキップ
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
118回答 すべてを表示
Why my tv won't turn on
Hello
My Mitsubishi tv model# wd-73833 won't turn on the green light turns on i press it to turn it on but it won't start up the fan goes on for a second then stops and repeat 3 times then the tv turns off. Please help what could it be???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@kckerler, Kerler, From forums I have looked at, these were known to have weak capacitor issues power supply/board. Below I will post a link to your TV's service repair guide. Try a reset as a 1st step from (RESET / INITIALIZATION GUIDE) page 24 in repair guide. Using the guide will tell how to read the diagnostic codes from your TV, tell you how to trouble shoot and possible causes and how to remove test components. Good luck.
https://philips.encompass.com/shop/model...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kerler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 213
