メインコンテンツにスキップ
The BlackBerry Passport SQW100-1 is a phone that has a physical keyboard and a touchscreen feature in one. Its square-like shape sets the BlackBerry Passport SQW100-1 apart from the other BlackBerry phones.
How do I get past the Finalizing Device Setup screen?
I turned my passport off the other day to avoid it ringing during a movie. Since I turned it back on two days ago, it has been in a loop where I get the 'Finalizing device setup' screen. It get to 100% and then restarts the whole thing over again. Have tried soft start from the power button, soft start from the volume toggle keys and most recently have removed and reinstalled the battery. Each re-set starts the pattern all over again. Help :-)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Try removing the SD memory card. Then restart the device.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have the same issue...uhg!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had this problem twice with my Passport. The only solution I’ve found is to re-install BB10 OS and it worked. Via BB Link, I downloaded BB 10 on my PC and could install it. Caution : BB Link cannot be installed on Windows 10, and you must know that you will loose all your data if you do so.
(excuse my bad english, I’m french)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Julie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 6,761
