How to fix 1907FPc 19" LCD Monitor feet from tucking?
it is stuck in the bothom
RENX , Check to see if there are removable plastic caps covering up screws that could be tightened to stop the screen from tilting. I had a stand that would keep tilting down on me and I wrapped a large an elastic around the hinged joint giving the problem and it worked. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 380
1件のコメント
What is "tucking" and can you elaborate more on your problem
Cameron さんによる
