Replaced Screen, works, but goes into boot loop, fixed by taking apart
My wifes iPhone 6 has water in it killed the screen but the water slash liquid wasnt like conductive, it was a medical water thing for the ears.
Anyway ordered a new screen replaced it all and it worked fine. But the next day it turned off, i took it apart again and as soon as i got the screen off it turned on and worked perfectly. So issue is once i close it it stops working.
It happens when i put the top pins in and bend the screen into to close someting seems to be making it reset into a boot loop and dead.
Any ideas?
Update (03/15/2017)
UPDATE
Hi Team, so i managed to replace the camera & battery. First two days it worked perfectly everything is back to normal. No restarts no crashes.
Then today, it seemed I was bit rough in my movement with the phone and it crashed and restarted in my hand.
So, so far replaced:
- Main Camera
- Battery
- Screen
Basically if you hit it hard enough in your palm it restarts.... Any ideas what could be causing this?
この質問は役に立ちましたか?
6 件のコメント
Also if you shake it when it turns off it boots up again, but as soon as its in desktop it turns off again.
Patryk Lazarz さんによる
Unplug the front camera ribbon cable and see if it still boot loops.
Ben さんによる
Hey mate, which one is that ?
Patryk Lazarz さんによる
It is the first cable you disconnect.
Gigabit87898 さんによる
Hey Ben, i did the camera thing first, no back facing camera but the %#*@ phone works fine after a full recovery.... wtf
Patryk Lazarz さんによる
1以上のコメントを表示
