メインコンテンツにスキップ
LG Power Tracfone, ran on Android's 5.0 Lollipop platform with a 4.5" FWVGA Display, Model (L22C).
17回答 すべてを表示
How to bypass Mcaffe mobile security pin?
I found a lg power on eBay for 12 dollars, it has a cracked screen and has a pin lock for Mcaffe security. It says it has been pin locked. Is there an equivalent to Odin for LG? Or how to factory reset it to get rid of it? It has a clean esn.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
Hi @gigabit87898 ,
Is this what you want?
http://phonefirmwares.com/usa-lg-x-power...
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
I need something like that, but that is not the same phone. What would I use to flash it? Could I use Odin?
さんによる
Hi,
Here is a link to download the LG flash Tool.
Unfortunately I cannot find any kdz file (ROM) for your particular model. You may have better luck. I tried looking for LG L22C assuming that this is your model, sorry about the mix up before, missed the X only saw LG Power not LG X Power.
Here is a link to the page that tells what to do
http://lgflashtool.com/
Here is a link to the download page
Download link is in the middle of the page 3.1MB .zip file
http://lgflashtool.com/download/#.WLwT7t...
さんによる
Do you think a rom from a lg leon would work? It is almost the same but the Leon is GSM and not cdma.
さんによる
@gigabit87898 if it is GSM not CDMA do not try it. Exactly what phone do you have? I thought it is a LG Power as well....
さんによる
コメントを追加
Sorry about the late answer, Gigabit. Just hold the power and down button until it gets to the boot options, select factory. Factory as in Factory reset. Initiate it.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Here is the link to download Lg Flash Tool
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Gigabit87898 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 3,942
