メインコンテンツにスキップ
Apple iPhone 5cは2013年9月10日に発表されました。このデバイスの修理は前モデルと類似しており、スクリュードライバーとこじ開けツールが必要です。GSM か CDMA、8, 16, 32 GB 、色は白、ピンク、黄色、ブルー、グリーンがあります。
1234回答 すべてを表示
Replaced front panel, ear speaker doesn't work now?
I recently replaced my front panel and all went well... everything worked great for about 2 weeks, but now my ear speaker doesn't work at all. All phone call have to be made using speaker phone or ear buds because I can't hear anything. I tried taking it all apart again and putting it back together to make sure I didn't have a loose connection, but it didn't help. Can anyone help me? Any ideas? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
After taking it apart 3 more times and reconnecting everything...it's working again! Hopefully everything continues to work! Thanks everyone for your responses!!
さんによる
コメントを追加
3件の回答
Either a connection broke loose or it just plain broke. You might just need to replace it. Im not going to put a link of how to do it as you already seem to know how.
Hope this helps and good luck fixing!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hi
its pls check speaker connection is good or not by using multimeter... put optiom in beep mode and check the two point in two probes if its beep comes your speaker is working.... if its not working replace the new one and check 100% its works
ear speaker
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If it worked fine for two weeks and you haven't dropped it or got it wet, most likely the ear speaker, shown in the picture above, is not aligned with the front camera and sensor flex cable. You should be able to get it working by re-aligning the ear speaker with the gold contact points on the flex, and make sure you put the correct screws holding down the ear speaker bracket to secure the ear speaker down properly so it doesn't move.
Alternatively if it does not work, it may be possible that either the ear speaker itself, or the front camera and sensor flex wen't bad. However, these parts don't go bad "just because"
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Morgan Riley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 51
