メインコンテンツにスキップ
The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
47回答 すべてを表示
My Bose Soundlink Colour isn't turning on
I havn't used it for about a month and a half but when I charge it the light, lights up and flickers orange until it is fully charged but after I unplug it i press the power button and it doesn't turn on. Even when it is connected to a power cable it doesn't switch on it just flickers that the speaker is charging. Anyone know how I can fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Can't get my power to come on after trying to hold 15 sec.unplug then plug working when I got it 2 weeks ago now no power help.
さんによる
コメントを追加
1 件の回答
Hi, I have the same problem, even if the battery is charged, although for some unknown reason it does tend to self discharge over a couple of weeks.
The only solution I’ve found that always works for me , even if it is fully charged is to attach a charger for a short period of time, a minute is usually enough. If you then disconnect the charger you’ll be able to switch it on, it’s almost as if it goes into some sort of deep sleep mode.
Mine is a version 1 of this speaker, friends who have the SoundLink II don’t seem to experience this problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jeffcamenzuli さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 734
