i'm trying to set up my wireless mouse to window 10
how do I set up my wireless mouse my dell laptop please and thank you
You plug in the dongle to the Computer and turn on the charged up mouse.
このアンサーは役に立ちましたか?
Does it make a sound on plug in?
no this didn't work , I've been trying to set the up now for the longest time
このアンサーは役に立ちましたか?
Texxi's suggestion only functions if your mouse is designed with plug and play drivers for window's 10. some items do not have that.
In order for plug and play to work, you will also need an internet connection on your PC as well, so that windows can download the drivers for you.
you may also have to Manually run Windows Update with "Optional Updates" through the Start menu to get it running.
Specifically, you will have to go to your mouse's support website, and find the manual driver installation package for windows 10. This is assuming your device specifically is designed for use with windows 10. if it is not compatible with the OS, it will not work.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 66
