メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 baseband problem
Hey guys, so two months ago I bought an iphone that was somewhat faulty. Sim card didnt work but that was ok for me since I dont use the phone that much for purposes other than wifi. Recently, me not knowing that an iphone that doesnt support sim card has a baseband problem, i tried updating it via itunes and then i tried restoring but you know... I couldn't. I kept getting itunes error (-1). Now that I know it has something to do with baseband what are the possible fixes for that. The attached pic shows my phone's motherboard. I'm asking for help on what can I do? All I currently want is just to restore my phone since it is stuck in recovery mode? In the other hand, how can I fix my baseband? What should I do? What should I buy? Thanks in advance.
Also notice how those two wires (?!) near the sim card tray are disconnected, is that a problem? And what's those two burned things near the baseband? Thank you so much.
p.s If I connect my phone to itunes it shows my serial number.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
最も参考になった回答
This is a worked board, which in other words, garbage.
You don't know if the board has gone through what kind of mess, has been repaired or not, or someone attempted and failed to repair it, or just take this board for spare parts. The repair cost for baseband problem can easily exceed the price of good phones so there is little repair value.
The "wires" next to the SIM slot is insertion detection if I understand you correctly. The "burned" parts are RF PA ICs, which should not affect baseband but shows the extent of the damage.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Well, is there anything I can do to fix it?
さんによる
Ask a professional to fix it. If he quotes higher than you are willing to pay, then no.
さんによる
コメントを追加
hi bro my is icloud looked pls helf me connect to itunes pls
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
iphone 6 16gb pls bro how solution pls
さんによる
i phone x max how to un looked i cloud please help me
さんによる
コメントを追加
-1 error
First check pcb if broken or have something scratched , if ok check this ic
baseband chip
baseband cpu
Nand flash
First try reball one by one and test
If same prob error -1 ! Try reprograming chip by tools like WL
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Oti Kadriu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 20,241
