メインコンテンツにスキップ
Asusによって製造されれたラップトップコンピューターの解体と修理情報です。
2518回答 すべてを表示
I charge it will getting dim.
hi guyz...I had the same problem..when I plug out the charger my laptop getting bright..but once I charge it will getting dim..to used the laptop continues I just used hdmi or vga cord to display it in other monitor while charging...because I cannot used my laptop while charging because its very dim..i search some solution but it doesn't work at my laptop.. i'd adjust already the brightness of battery or plug in power option or setting..i also tried to removed the battery then press the power button but it doesn't work..kindly HELP ME PLEASE.. it almost 2 1/2 weeks I'm fixing the laptop but unluckly :( :(:(:(
here the specs:
- ASUS 201E
- OS FROM WINDOWS 8 UPDATED TO WINDOWS 10
- UPDATED HARDWARE
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
Hi,
If I understand you correctly the battery alone cannot run the laptop normally,i.e. screen stays bright and the charger cannot run the laptop and charge the battery with a bright screen either. Is this correct?
Perform the following to try and isolate the problem
1. Without starting the laptop, fully charge the battery. When it is fully charged, start the laptop on the battery only and watch what happens to the display. Does it stay bright or does it dim very quickly? If it dims it indicates that the battery is failing.
2. Switch off the laptop and remove the battery and then start the laptop on the charger only. Does the screen stay bright? If so, it indicates that the charger is working well enough to run the laptop and most probably is good enough to charge a good battery at the same time.
If the battery is failing it is probably dragging down the charger supply away from the laptop so that the laptop is not getting enough power for the screen to work properly
さんによる
Hi,
Another few questions.
Was it working OK before the upgrade to Win 10?
Was it working OK after the upgrade to Win 10 and has just started (2.5 weeks ago) or has it been like this since the upgrade?
さんによる
Try disabling ambient sensor --> fn + A
さんによる
コメントを追加
1 件の回答
Have you looked at the windows power settings?
Here you can choose what windows should do when the charger is connected or not. As you can see on the slide bar the brightness can be chosen also. Usually since it consumes a lot of power the brightness is dimmed when not connected. Might be that the upgrade from Windows 8 to 10 might have changed something in these settings.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi @bearl
I think that she already has tried this.
Quote from OP's question:
"....i'd adjust already the brightness of battery or plug in power option or setting....."
Cheers ;-)
さんによる
コメントを追加
回答を追加する
Anna Loisse Suazo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 747
