メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone not charging, "this accessory may not be supported."
I have this iphone 6 motherboard that works almost fine, exept it wan't recognise the charging cable, and the message pops up: "This accessory may not be supported".
I have tried "millions" of different cabels, originals too, but it dosn't work.
I can charge it by turning the phone of while it is plugged in, but that is no good...
I have tried with diferent ports too, dosn't make a difference.
I have tried updating/restorering the phone, didn't help.
Could it be fixed by jailbreaking the phone and mabye run it on an older ios?
Could it be the charging chip (U2)?
Thanks for your help :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
one thing that may cause your iPhone to reject your charging cable is that your charging socket/hole/connector may be full of dirt, like lint, or dust. a good way to clean this out is with a toothpick, carefully. alternate scraping the dirt out and blowing in the charger port to loosen the dirt. dirt in the charger hole may cause a poor connection, including the error message
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I tried conecting a completly new socket to the motherboard, didn't help.
The problem must be software related or some hardware failure on the motherboard
さんによる
コメントを追加
Try a DFU mode restore, if not then it would probably be the tristar chip.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
DFU restore didn't help ..
Guess I'll try replacing the chip then.
さんによる
コメントを追加
回答を追加する
anthonriis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 9,852
