Proximity Sensor failure after battery replacement
I just replaced the battery using instructions on this site and everything seems to be working except the Light/Proximity Sensor (the thing that turns the screen off when you hold the phone up to your face). Before I try tearing it down again, has anyone had any luck fixing this? I tried running the Light Sensor test (*#*#3424#*#*) and it registered a constant 4070 Lux. Not sure what that means. I'm wondering if one of the little cables that went to the upper left of the camera didn't get connected right.
Constant LUX means it is not detecting the light difference on the light being shined on the ambient light sensor.
There should be a proximity sensor test there in the test menu.
Also for battery replacement taking out the daughter board should not be required anyway it's most likely a connection issue to the proximity sensor which is plugged into the daughter board.
Or it could just be glue blocking the proximity sensor near the plastic speaker mesh cover.
Ben さんによる
