ipad air wake sleep sensor
Good morning, I replaced the tuch on a ipad air (full touch home button) .. but no longer works the wake sleep mode with the smart cover .. do not understand what may be the problem .. where is the sensor?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The sensor is the chips on the home button cable. Compare it to the old screen with the home button on it and you should see that one does not have the components on there.
If that is the case then you will need to transfer it via soldering.
このアンサーは役に立ちましたか?
Thanks for the answer, I doubt that the sensor was in the home key. I can't figure out what is the
Chip. Can you attach a picture.
My bad, the home button cable is soldered together with the screen.
It's just a bad digitizer then because most likely it didn't come with the IC required for the smart cover sensor.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 986
