water doesn't come out. Instead the machine makes a sputtering sound.
When it is time for the water to dispense into the cup the coffee machine makes a sputtering sound and no water comes out.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@pmnewt1 "makes a sputtering sound and no water comes out" sounds like a clogged puncture needle. Check on here how to clean it. different model same idea.
このアンサーは役に立ちましたか?
THANK YOU, THIS WORKED!!! It was working perfectly and I dumped the water out of the reservoir and forgot to put the tank back on. When I got back from my two week vacation it wouldn't work. I used the pin in the holes technique.
過去 24時間: 1
過去 7 日: 10
過去 30 日: 18
今までの合計 2,895
