galaxy s7 waterproof when l fixed
hi guys
I have a some problem that my galaxy s7 broken the back screen so I tryed to self repaired and i fixed
so can s7 still be waterproof?
If you had access to the same adhesive Samsung uses and followed the exact same procedure they use for sealing the device, then it should have the same amount of water resistance. However I am assuming you don't have access to these as Samsung hasn't released them to the public so it would be best to assume the device is not as water resistant lest you get a rather nasty surprise.
このアンサーは役に立ちましたか?
You will likely lose some of the water resistance.
The phone was never water proof.
It can handle the rain, but you can't take it swimming.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 876
