メインコンテンツにスキップ
Polaroid Sun 600 LMS instant camera. Released 1983.
15回答 すべてを表示
The red light seems to be stuck & doesn't seem to be properly working
I'm aware that I have to half-press on the red button in order to change the flash for my Polaroid.. But the red light will not turn off and change to green, and I have been waiting for several minutes.. What's wrong? It just randomly stopped working and I cannot take another photo until the light turns back to green.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
natjarmay, Both the electronic flash and the camera are powered by the high-energy battery built into
every film pack. Clean the film pack contacts in the camera with a Qtip dampened with 90% Isopropyl alcohol and install new fresh good quality film pack and try the camera.
If this does not solve the problem there could be a problem in the Flash circuitry.
file:///C:/Users/Home/Downloads/600-manual.pdf
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
How would you recommend properly cleaning the film pack contacts?
さんによる
natjarmay , the link below will show how to open th film pack door, with a flashlight you can look inside the compartment and see the copper contacts which should be reachable with long Qtip dampened with 90% Isopropyl alcohol, gently clean the contacts to remove any dust/corrosion/etc., You could also use a can of compressed air to blow out any dust/debri that you see.
Polaroid Sun 600 LMS Film Pack Replacement
さんによる
コメントを追加
回答を追加する
natjarmay さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 15
過去 30 日: 85
今までの合計 9,261
