I cannot connect to the network. It has a locked icon on the WiFi logo
says authentication error occured.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It sounds like the password to the signal was changed.
What you need to do is go into Settings --> Wifi, and find that WiFI profile.
Select it, and choose "Forget".
Once that is done it will ask for a new password when you try to reconnect to it.
このアンサーは役に立ちましたか?
It seems like the Wi-Fi password has been changed, go to settings, select connections, select your Wi-Fi and press forget that network, finally select again and enter the new password
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 10
過去 30 日: 38
今までの合計 1,873
