メインコンテンツにスキップ
2012年11月に発売されました。GoPro Hero3はWi-Fi対応、4K解像度のデジタルカムコーダーです。
104回答 すべてを表示
How can I get wifi password?
I order GoPro Hero3 Black Full Assembly and I received.
And I try connect to wifi, but I cannot.
because I don't know password.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
Very simple, if you are matching for the first time, the default password is "GoProhero". If you have forgotten your previous password, you will need to visit the GoPro official website to re-update your ID and password. This is the step:
Step 1, go to the Hero3+ page > "Other update methods" > select "Manually update camera".
In step 2, go to the page where you filled out the details and fill in the information, including your serial number and registration information > "Next".
In step 3, select "Wi-Fi update only" > "Next".
Step 4, follow the instructions to complete > complete.
Here is a more comprehensive introduction: https://www.fonecope.com/how-to-reset-go...
さんによる
@antonton Just wanted to update this as currently there is no option to update WiFi settings that I could find. The only option is the full Manual Update which does not affect the wifi name/password. Managed to solve this after speaking to support and some experimenting.
Support linked me to these instructions, which I had not found before despite much digging and which are dated July 15th 2022: https://community.gopro.com/s/article/So...
However, if you try to download and install either the full Manual Update or Wifi Update as described nothing will happen. The workaround I found was:
> Follow the link to download the file at the bottom of the main Hero3 Manual Update page (or in my case Hero3+): https://gopro.com/en/ca/update/hero3
> Unzip the file simply named UPDATE.zip
> Download the Wifi Update from the July 15th page and unzip it
> Open HERO3 Wifi Update
> Move the files INTO the main UPDATE folder
> Then proceed with the update as normal
さんによる
This worked (cristianmail's post), I had to create my own manual files, then add them to the download pack of either links from Stefan and it worked.
Make sure to leave the go pro app every time to make sure the connection is starting fresh each time.
さんによる
コメントを追加
2件の回答
ベストアンサー
1.Connect your GoPro to your computer. (Alternatively, you can also just insert your
microSD card using an SD card adapter)
2.Download the file from the link at the bottom of this post
3.Extract the zipped folder
4.Copy the contents of the folder and paste its content to the root folder of your GoPro’s microSD card.
5.Paste the whole “UPDATE” folder to your GoPro’s root folder. The files must be in a folder with the name “UPDATE”, otherwise it won’t work.
6.Unplug your GoPro. It should automatically turn off.
7.Turn it back on. Your GoPro should display now that it’s updating. Once it’s done it will turn off again.
8.You can turn it back on now and connect to its WiFi network with your device using the default login:
Network name (SSID): GoProHero
Network password: goprohero
Download link, replace the $ with a period after net because otherwise it'll delete my answer http://trendblog$net/download/files/GoPro_Hero3+_Black_WiFi_Reset.zip
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thank you your help.
I did it the way you told, but I fail.
But I found the way at the site you mentioned and I Success.
My Gopro type hero3, (not hero3+).
That's just the reason. ^^
Thank you!!!
さんによる
Glad I could help @bbogle ! Please vote up my answer and mark this as solved. :)
さんによる
page not found :((
さんによる
コメントを追加
Simple and easy to follow guide : https://youtu.be/LvVSQqCqfPA
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
KIMBOGEUN さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 57
過去 30 日: 273
今までの合計 40,870
