Can I rescan the channels without a remote
Family channels on my RCA digital converter with no remote
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Unfortunately the answer is NO.
The only way to program the converter is by either using the dedicated remote control or obtaining a universal remote control unit which states that it supports your particular model converter. (By using the appropriate code in the universal remote it essentially becomes a dedicated remote).
You might also look on places such as Ebay to see if your particular model converter has a remote available.
Bit confused as to whether you have an AccessHD converter or an RCA converter so selected AccessHD,( as you showed both in the question area). If you have a RCA converter just search Ebay for (your model converter) remote control unit to find results
Here is a link that shows a lot of remote control units for AccessHD converters. As you didn't state your particular model I couldn't find the exact one. Just scroll through to find your particular converter and then the remote that works with it. If there is more than 1 available select the one that suits you best.
This is not a recommendation to use any of the sellers listed. It is shown to give an idea of what is available and how much it costs.
http://www.ebay.com/sch/i.html?_from=R40...
Hopefully this is of some help.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 10
過去 30 日: 46
今までの合計 6,501
