The underneath image is cracked. What do I need to fix my phone?
My htc windows 8x was hit with a golf club when in its case. The screen isn't cracked but the underneath image is. What do I need to fix my phone??? Any info will help.
Hi,
Here is a link to a video that shows how to replace the LCD screen and Digitizer (touchscreen) on your phone.
https://www.youtube.com/watch?v=Zp0JoXbp...
Here is a link to just one supplier of the part. It is not a recommendation to use them. It is shown to give an idea of the cost of the part. There are others online that may suit you better.
http://www.etradesupply.com/htc/windows-...
If you find the repair too daunting to do yourself then I recommend that you contact 3 reputable, professional mobile phone repair services and ask for a quote for a repair. I suggest 3, that way if all the repair estimates are close you will have a truer indication of the cost of the repair. You should already know the cost of the replacement part.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
You need a new LCD display. Here is the link for the part that i would recommend: http://www.ebay.com/itm/LCD-Digitizer-Fr...
You can get cheaper parts but that one will require the least labor and will be pretty easy to fix. (since there is no separating or any other risky work required.)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 62
