メインコンテンツにスキップ
Moto G4 PlusはMotorolaのMoto G4モデルの改良版です。Moto G4 Plusは指紋センサ、増量したメモリ容量、改良されたリアカメラが搭載されています。モデル番号はXT1642とXT1644です。
73回答 すべてを表示
I dropped a 70 pound weight on my face down MotoG and it doesn't turn
I dropped a 70 pound weight on my face down phone and it doesn't turn on. The phone is slightly bent but no other visible damage. I took the back off down to the battery but can't see any thing wrong. Is there some troubleshooting that I can do to see what to fix or replace?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Kevin Egle post some images of your damaged Moto phone. It is possible that you have a bend logic board as well as a lot of other things that may have failed. Use this guide iFixitでの質問に画像を追加する方法 to post images. It will allow us to see what you see.
さんによる
コメントを追加
2件の回答
ベストアンサー
Kevin, here is a disassembly guide.
https://www.youtube.com/watch?v=AoNd1B0x...
I have one of these. The battery back cover comes off, but the battery is not supposed to be removed normally.
1) take apart this phone and see if the battery has been disconnected in some way from the logic board
2) see if theres any damage or deformity to the logic board. If you are lucky, the battery somehow just got disconnected
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Which generation is this? iFixit has some guides you might follow to disassemble it.
Depending on how much damage your weight did, it may simply be as simple as replacing the screen or simply knocked the cable for the display loose. But if it it internal damage, it will likely need a new logic board. If you press the power button and you can feel it power on (i.e. it vibrates or makes sounds), it may just be a display issue.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Moto G4. Nothing happens when I push the power button. No visible connections are bad.
さんによる
コメントを追加
回答を追加する
Kevin Egle さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 6
今までの合計 138
