メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Note 5は2015年8月に発売されたSamsung製のスタイラスペン付きファブレットスタイルのスマートフォンです。
My unsolved at&t sim problem
just recently gave my wife my note 5 took my sim card out and hers in the note 5 and it doesn't read it, her sim is from another at&t account they changed the info on there end and it worked fine for a week or 2 now it doesn't read it at all only wifi works we have been to 2 at&t stores they switched sim cards and even put one of there personal sim cards in it and it works fine my sim also works fine in it PLEASE HELP my wife is driving me up the wall
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You need a new sim card . It may be damaged or marked up to the point where the pins in the card reader cant make a good connection. Get a new card and have them move her account to the new sim . If the phone works fine with other cards then its the sim thats the problem. Hope this helps
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
that's the thing they put a new sim card in it also they have no clue whats going on
さんによる
try again someone didnt do something right when they switched it over
さんによる
Hi,
What size is the SIM, is it a micro and you are using an adapter?
Either way, try cutting to size a bit of paper and place it on the non contact side of the SIM card and insert the card+ paper into the card reader. Initially leave it longer so that it can be easily removed if it makes no difference.
The idea is to increase the pressure that the SIM card places on the reader contacts to make a good connection.
さんによる
thanks guys for the help i convinced them that it was there fault they sending me a new note 5
さんによる
コメントを追加
回答を追加する
Albert Tennant さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 153
