メインコンテンツにスキップ
このモデルは、SM-G530H / DV Samsung Galaxy Grand Primeで、白、グレー、またはゴールドのケースのカラーバリエーションがあります。
146の回答 すべてを表示
Samsung grand prime smg530A is changing screen
After having a shattered lcd and digitizer screen and replacing the motherboard. The phone will power on (the motherboard had a factory reset ) perfect quality picture. But after a few mins of recording ,moving icons around, going into different settings.
The screen responds has it should, but then it comes alive on its own, switching from one screen to another for a while.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
2件の回答
最も参考になった回答
@loyates this is usually caused by errors between the LCD and digitizer, most often on aftermarket repair assemblies. Replace the display assembly to eliminate this error.
この回答は役に立ちましたか?
スコア 1
コメントを追加
there might be a prblem with the ribbon cable connection. if you are able try to take it back apart and make sure that 1 there are no breaks or any damage to the cable or the port and 2 make sure that it is connected securely. i hope that this helps
この回答は役に立ちましたか?
スコア 0
コメント:
@aebelcarris /@oldturkey03 Thank you for that information, however this is my second screen assembly (the second was a replacement for the first that was missing the ribbon clip)
As of 4 hours ago I hard reset the phone (knew motherboard ,so no information was lost) and I am cautiously saying it is not acting up. Fingers crossed will keep yall posted
by
Well the phone is still switching from
screen to screen. It actually goes into the messages, contacts, settings, etc. Does this for few goid mins.
Go to push the power off button, but it won't stay on the screen long enough to select off.
by
コメントを追加
回答を追加する
Lisa Yates さん、ありがとうございました!
統計データを表示:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
今までの合計 230
